Update in VATS bypass...
Old Sep 16, 2000 | 10:58 AM
Bill91Z
Guest
Posts: n/a
found the small wires I was looking for, I think. They are 2 24 gauge or so white wires coming from the column to a small clip. From the clip come two small wires white/black, purple/white. Is this what I'm looking for? I should wire the resistor across the striped wires right? These are the ones that would tell the ECM what resistance I have?
Thanks guys
-Bill
-=ICON Motorsports=-
Boston Chapter
91Z28, (in progress) 3.8L, TE63-1 turbo, MSD50lb injectors, Hemco upper, ported TTA heads, 62MM TB, Red's XP fuel pump, 3.73s, vigilante (stall to be determined)
[This message has been edited by Bill91Z (edited September 16, 2000).]
Old Sep 16, 2000 | 12:46 PM
Andy89RS's Avatar
In mine the VATS wires were orange. If you're not sure, plug a multimeter into the side leading to the ignition switch, put the key in the ignition, and turn the key back and forth. In most cases, you have an intermittent contact, not a completely broken one, so you should see some changes in the resistance your multimeter sees. If nothing else, measure the resistance of the chip in your key and hold the right size resistor across the plug you think is for the VATS and try to start the car. (You might need someone to turn the key while you hold the resistor in place) If it starts, you have the right set of wires.
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
RS Reaper
Oct 17, 2018 07:52 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
2012sergen11
Oct 13, 2015 07:38 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
aharvel50
Sep 21, 2015 07:31 PM
