my modded 87GTA got beat by stock 89GTA-WHY???
Old Sep 14, 2000 | 02:11 PM
Brandog87GTA's Avatar
The guy I raced said he has his stock,well I have put in a shift kit,airfoil,flowmaster, JET stage 2 chip, 160 stat, Mobil 1 oil, k&n air filter, accel wires and rotary cap with bosch platinum plugs. My car has a code 34 which causes the check engine light to always be on, i cant get it to go away. Could this be part of the problem? he put a good 2 cars on me and I shoulda beat him.We both have the 350 tpi's. His had 97,000 miles, mine has 175,000
Bright red 87 GTA with 350 tuneport. Basic mods such as K&N filter, Flowmasters, Wells MAF, TPIS air foil, Accel 8.8mm plug wires with Bosch platinum plugs, Accel distributor cap and rotary buttons.Gutted cat. Hope to port runners and plenum in about 2 weeks.
Old Sep 14, 2000 | 02:20 PM
iceman86TA's Avatar
well, first of all, the stock 89 has more horsepower than a stock 87. If I am not mistaken, the 89 came with about 20 extra ponies. So he has a little more to work with. Then you have quite a few miles on that engine. Its possible that things are slowing down some. Also, a good tuneup could improve things from you side. This may not be all that was at work, but I think I hit a few factors.
ice
Old Sep 14, 2000 | 02:24 PM
What about the code 34, It runs better when the code isnt on. Does my chip even help me any if its in limp mode? Or does it matter? The chip itself shoulda given me enough to take him.I also have a cowl hood which loses like 70 pounds of weight.
Old Sep 14, 2000 | 03:06 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
160 stat, Mobil 1
platinum plugs
Those aren't mods. That's a tune-up. The only real mod that you have is the chip, which is still only worth .1 in the quarter at the most. The flowmaster might be worth a couple horsepower, but chances are he's got an exhaust too.
Your code 34 means that your mass airflow sensor is dieing or dead, which will seriously kill your performance.
I
30 pounds max. That's about than .03 in the quarter.
The fact is, I think his car still has more horsepower than yours, especially if you were throwing a code when you raced. Even without the codes, the cars would be very equal and driver skill could certainly account for at least a 2 car gap.
Old Sep 16, 2000 | 03:53 PM
86 TA's Avatar
1st check your MAF relay by switching it with the burnoff relay if the computer throws a code 36 u know its the relay, then check ur TPS voltage this caused me to throw a code 34, also check to make sure there are no vacuum leaks between ur MAF and plenum... also u make no mention of the rear gears, maybe his just launches better....good luck!
86 TA, 5.0 TPI, Automatic, 53,000 orig. miles, pretty much stock...but that will change!
[This message has been edited by 86 TA (edited September 16, 2000).]
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
PestilenceIV
Aug 20, 2015 02:33 AM
NWAsonoma
Aug 18, 2015 05:45 PM
matthew911
Aug 12, 2015 09:38 AM
