rear end ques
Old Sep 15, 2000 | 01:56 PM
jmon92conv's Avatar
rear end ques
Help me out here, I know where a posi disk brake rear is out of a 88. I have a 92 Z with drum. Is it worth the switch or keep looking for a newer 10 bolt with disk?
Glad to be back up online.
92 z conv
5-spd
few upgrades but working
just installed Alston sfc
Old Sep 15, 2000 | 06:31 PM
jmon92conv's Avatar
come on guys, tomorrow is the only chace I can get it for a month
Old Sep 15, 2000 | 06:39 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Did the switch from drum to disc for various reasons, but frankly I'm not sure the effort was worth the money or the results in braking power. If you're a regular street drive, save your money and effort.
JamesC
Old Sep 15, 2000 | 06:53 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i'd stick with what you have. your not likely to gain much by switching unless your racing or drive hard alot. might be better off just doing a conversion on your rear end by adding discs to your housing.
Old Sep 15, 2000 | 07:04 PM
jmon92conv's Avatar
I race it in SCCA events here local. I was wondering if it was worth it with the smaller axles and if the brakes were up to par with the 89 and up J65.
Old Sep 15, 2000 | 07:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I would say it's not worth it. The 88 back disc brake system sucks, though the rear itself might be the BW 9-bolt, which is said to be a somewhat less weak piece than the GM 10-bolt.
Hold out for one with the later disc system if you're looking to do a brake upgrade.
Old Sep 15, 2000 | 09:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The 92 has 28 spline axles. The 7 5/8" ring gear still isn't as strong as the BW 7 3/4" but the larger axles are a good start on a 10 bolt that can be made even stronger.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Sep 16, 2000 | 02:11 AM
jmon92conv's Avatar
thanks for the help everyone, if someone knows of a good disk system out of a 91-92 near Indiana, e-mail me OK.
Jeremy
Old Sep 16, 2000 | 03:31 PM
JP84ZROC
Guest
Posts: n/a
I'm nowhere near Indiana but I just picked up a '92 rear disc, posi, 3:42 for my '84 Z28 for $300......guess i am gonna have to update my sig.......HEHEHE
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Old Sep 16, 2000 | 10:55 PM
jmon92conv's Avatar
must be nice, I am about ready to go to TX to get one. This sucks not being able to get what you are after.
Jeremy
92 Z conv
5-spd
alston sfc, few other mods,no big deal
Old Sep 17, 2000 | 07:38 AM
Biochem's Avatar
Car: 2002 SOM z28
I replaced the 3.23 open drum in my 84z28 with a pre 87 9-bolt posi w/ 3.27s. I love the fact that I have a posi vs an open. I no longer get the 1-wheel peal and my handleing is better for it too. 3.27 is the optimal gear ratio for the 700R4, but it isn't much of a change from the 3.23s I had.
As for the addition of disk brakes, I don't really care. They look cooler (added Powerstop cross drilled rotors), but they don't stop any better/worse then the drums did. I bet it is a few extra pounds off the rear though.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
