This is for all the experts....
Old Jun 2, 2003 | 05:12 PM
restoIROC's Avatar
Car: 2000 Monte Carlo SS
Engine: 3.8 V-6
Can the 86 305 TPI run with only a set of shorty headers bolted on? I have heard so many different stories about aiir leaks and the O2 sensor malfunctioning. The IROC shows no codes, fires, then immediatelt dies. I only have headers on. Do I tow the car and get the y-pipe made, then try it or what? Man, this would help me out alot
Any help is much appreciated-
Ben
Old Jun 2, 2003 | 05:53 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
well, im no expert but i drove my car with open headers. i have 87 firebird with the stock 350 tpi, i put on some hedman shorty headers on at my friends house and i had to get it home somehow! so, there i was driving with open headers down to my house which was a good distance away
it actually never died or anything. i put in a bushing on the header for the O2 sensor then drove away and never really had any problems.
man was it LOUD!
Old Jun 2, 2003 | 08:15 PM
restoIROC's Avatar
Engine: 3.8 V-6
what do you mean...."a bushing"? That was the only thing you did and it ran fine? Wow.....
Thanks for posting, Ben
Old Jun 3, 2003 | 03:36 AM
1a12's Avatar
try the easy stuff first. It almost sound like a wire of some sort got unplugged. which could be very important.
Check the wires around the headers and make sure they are all plugged in tight.
Old Jun 3, 2003 | 04:13 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Yeah , it should run without the exhaust...it May just throw some codes. Sounds like a fuel delivery problem to me...What work did you just do to your car..only new headers? Sounds like the fuel pump may be priming, but not coming back on. Check your Fuel pressure.
Old Jun 3, 2003 | 10:17 AM
restoIROC's Avatar
Engine: 3.8 V-6
thanks guys,
I have researched and I think it is the MAF. The computer had been throwing MAF codes out for awhile, but now they are gone so I will try to unhook it and see if I can keep it running. I did take it off when I replaced the old thermostat so, yeah....I am going to check all the connections also-
Thanks- Ben
Old Jun 3, 2003 | 08:42 PM
Engine: 406
Re: This is for all the experts....
Originally posted by restoIROC
The IROC shows no codes, Ben
OK....
magikstik1977
Jun 12, 2012 10:01 AM
Stevie
Jan 23, 2004 08:24 AM
