what to do...
Old Jun 3, 2003 | 12:20 PM
mpitts77's Avatar
what to do...
My stock TBI manifold off my 305 in my 92 RS will not blolt right on my 70-76 model 350 block. Should I get a Edelbrock TBI manifold? or say fug it and go for a carb. If i go carbed..can i still use my stock fuel lines? what all will I need to get to convert to carb.?
Old Jun 3, 2003 | 12:29 PM
5.7Camaroboy's Avatar
Car: 85Z28
Engine: TPI355,383LT4
Transmission: 700-R4,T-56
go carb i say it flows alot better then tbi and responds better to mods that tbi will most likely hold you back.
Old Jun 3, 2003 | 12:30 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the inside 2 bolts on the manifold are diffrent for pre-87 and post 87 heads, you need to elongate the 2 bolt holes in your manifold to make it work.
also the edelbrock manifold will have the same problem
you can also get a 4bbl manifold from pre-87 heads, and then use a 4bbl to TBI adaptor plate.
Old Jun 3, 2003 | 12:33 PM
mpitts77's Avatar
who makes the 4bbl to TBI adaptor? I got the $$ wouldn't it be easier to just get say like a edelbrock performer RPM manifold..don't really have the tools to do any machine work.
Old Jun 3, 2003 | 12:49 PM
mpitts77's Avatar
fug it..im ditching the TBI
Old Jun 3, 2003 | 01:26 PM
Dewey316's Avatar
Car: 1990 Camaro RS
holley makes an adaptor, and so does turbo-city, there are probably other too.
camaro922k3
Apr 17, 2004 10:02 AM
F-Body Tim
Apr 8, 2004 11:16 PM
F-Body Tim
Mar 20, 2004 06:45 PM
benoit454
Jan 28, 2004 06:05 PM
BluByU
Jan 15, 2004 10:36 AM
