1LE pulley
Old Jun 3, 2003 | 08:27 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
1LE pulley
Think I'll ditch my non-funtioning air cond and put a 1LE air delete pulley on.
Can I use the stock belt? If not, which one do I need?
Old Jun 3, 2003 | 10:30 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Stock belt will be just fine. That's what I used and never had any problems so far.
Old Jun 3, 2003 | 10:32 PM
MdFormula350's Avatar
yes you can use the same belt you have now.
the delete pulley i believe is the same size as the a/c pulley.
i had to get a bigger belt because i deleted the smog pump which needed a new belt routing to work right.
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
evilstuie
Sep 24, 2015 02:31 AM
