Broken Plug
Old Jun 4, 2003 | 06:52 PM
Black89GTA's Avatar
Broken Plug
I really screwed myself. I broke off a plug at the base of the hexagonal part, which means the threads and a little more is still in the head. Any suggestions would be appreciated.
Old Jun 4, 2003 | 09:44 PM
25thanniversZ's Avatar
if ya have enough room try a reverse drill bit or an ease out ,be kinda rough but its all I can think of
Old Jun 4, 2003 | 09:51 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Now we know why anti-seize if so important. Try what 25th recommended. If that doesn't work, you'll probably have to pull the head and take it to a machine shop.
Old Jun 4, 2003 | 11:40 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
can you get a grip on the ceramic? it should pull out with little effort because the crimp above the hex is what keeps it sandwhiched in there, and since that's broken then there's not much holding it in place. then you can maybe find a really big easy out and put it in the hole through the plug shell and back it out.
Old Jun 4, 2003 | 11:49 PM
might try a little heat from a propane bottle to, help loosen it a little
Old Jun 6, 2003 | 05:06 PM
Black89GTA's Avatar
Thanks for the help guys. I got it out with a propane torch and an easy out.
db057
Apr 28, 2019 07:45 AM
skeltor
Feb 2, 2016 10:37 AM
Jlanz55
Sep 9, 2015 09:09 AM
snakeshooter
Sep 7, 2015 11:15 AM
89 formula TPI
Sep 7, 2015 11:06 AM
