oil [ressure gauge
Old Jun 5, 2003 | 04:32 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
oil [ressure gauge
where can i tap into the my 88 formulas 305 tbi motor too temporarily hook up a oil pressure gauge
Old Jun 5, 2003 | 05:49 PM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
On the drivers side of the block just below the spark plugs there will be the oil pressure fitting which you should just be able to remove and screw in your own guage. You might have get an adapter if the new one isn't the same thread size but otherwise you should be all set.
Old Jun 5, 2003 | 06:07 PM
ede's Avatar
ede
or around 11 o' clock above the timing cover, or on the china wall near the distributor
Old Jun 5, 2003 | 06:58 PM
Car: 83 Camaro
Transmission: th350
i cant really see.....does the stock intake cover up that hole.....another thing....will my pre 85 edelbrock performer intake fit it this motor?
Old Jun 5, 2003 | 07:43 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
It shouldn't cover the hole on the china wall at all. I am going to switch and use the one above the oil filter. I have a real bad leak on the one by the dist.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
