What do all the cam specs mean? For example, this is the specs for a Crane Cam:
lobe sep, 112 deg. , Avd Duration Int/exh, 260/272
Valve lift int/ exh .427/.454
It says that that cam is rated from 1000- 4500 rpm.
What does the lode separation really do? How about the Duration and Valve lift? What does @50" int/ exh mean? How exactly is a cam rated for an rpm range? What does the rpm range depend on? Thanks a bunch for any info,
Danny
Danny
Chevy High Performance had a great article in a recent edition. Here is most of the article:
http://www.chevyhiperformance.com/te...48_0307_basic/
Now I just need to get more info myself on how to do the swap. But this article has a lot of good info.
Thanks alot guys!
