header install question
Old Aug 2, 2000 | 12:55 AM
daniel dekay's Avatar
i am installing my new edlebrock TES headers on my 86 camaro 350ci and i ran into a problem. the power steering bracket wont bolt up to where it used to be. has anyone else had this problem with these particular(or any other brand) headers? what did you do to remedy it? i need help on this quick. thanks alot
daniel
Old Sep 19, 2000 | 05:42 PM
valu8or's Avatar
I am having the same problem and this is the only post that comes up with the search function. Can anyone help? please...
Old Sep 19, 2000 | 07:43 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i never put those brackets back on with my hedmans
86 Camaro with 88 305 LB9 converted to carb, edelbrock performer manifold, S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermo, and fan switch, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Sep 19, 2000 | 07:46 PM
valu8or's Avatar
What is holding the power steering pump? I also have hedman's and cannot figure out how to mount the power steering pump.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
drathaar907
Aug 6, 2015 04:20 PM
