Alternator going bad?
Old Jun 7, 2003 | 09:17 AM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Hello all, I have a real quick question for you guys. I have noticed like in the last two days or so, at night usually that when I have my headlights on and foglights and I am driving my voltage guage is only at the dash marked 8! (Even when I am accelerating) Usually I remember it being at least above the 12 dash mark.
Is this my alternator going bad? This wouldnt have anything to do with the battery correct? My other problem is if it is my alternator, I have it polished/chromed so is there some way that I could just get new internals or something to fix it and keep the outside casing? If so where would I be able to get these parts and would any garage be able to fix it?
P.S. - Car starts fine....
Old Jun 7, 2003 | 09:54 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
before ya go replacing/rebuilding anything make sure your connections are tight and clean
Old Jun 7, 2003 | 10:26 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I would also measure voltage with a multimeter at the connections. I wouldn't rely on the dash gauge, other things could cause that gauge to act funny.
Old Jun 7, 2003 | 01:17 PM
Vader's Avatar
It's easy to repair an alternator. But before you dive in head-first, make sure you know what the problem really is. The alternator may be fine. You've been given good advice - check all the connectiopnos first and verify the alternator output under load with a separate voltmeter.
Old Jun 7, 2003 | 01:39 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Like said above, check your connections before you start replacing things. I know from experience
Old Jun 7, 2003 | 04:14 PM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
I will check the connections first then. If that isnt it then I will stop up at autozone to get it checked. Thanks guys I'll check back.
Old Jun 9, 2003 | 03:21 PM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
I got it tested and it was bad. Well I took it to a alternator rebuilding place, I am getting it rebuilt since it will only be like 40 or so dollars. So thats it, thanks guys! Keep up the good work!:lala:
Hotrodboba400
Dec 10, 2019 07:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
sahlomonic
Sep 20, 2015 07:15 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
