Hard Starting Fixed!! (long)
Old Sep 19, 2000 | 07:49 PM
freeze92's Avatar
I wouldn't call this a common problem, but any of you who have tried everything to fix a TPI that didn't want to start up right might check this out. I have had a problem for about 2 years with my '89 GTA. It would turn over fine, but didn't seem to want too fire off. If I tried a couple of times to start it with no success, then let it sit for a about a minute, it would usually fire up. I tried all the "normal" stuff first: injector leak down, coil, plugs, wires, fuel filter, etc.. I finally bought an OTC scan tool to check it with. Turns out, that the scan tool could not get any data from my ECM. I could get a trouble code with a paper clip, but the OTC could not read the data stream. There is a test for this condition in Chilton's FUEL INJECTION AND ELECTRONIC ENGINE CONTROLS-1988-90 General Motors edition manual. I did the test, and it turns out that the ECM was bad. Now the car starts and runs like normal! This is probably not the problem that most TPI's have when they won't start, but it is a difficult one to find without a scan tool. Just some info someone might be able to use!
Old Sep 20, 2000 | 03:57 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
please tell me what the test is here so we can do it. it might help me!!!!!!!!!!!!!!
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.members.tripod.com/~Astra...uild/front.htm
or click below to email me
Astralbaby@webtv.net
Old Sep 20, 2000 | 05:11 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Tell me....tell me.......
I also have a starting problem that I cant figure out and my scan tool has some problem connecting to the car.
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Frozer!!!
Jan 19, 2024 04:55 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
cstrobel65
Aug 15, 2015 10:19 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
