What isthebest Engine RPM Where Peak HP will Occur
Old Sep 20, 2000 | 02:35 PM
Metallica383's Avatar
I am trying to figure where the most power is being made on a 383 with 10.1 pistons comp cam 268H and 2.02 heads it will be fueled by a 750 demon carb. I was also wondering how high can you safely rev a 383 with stock rods?
Old Sep 20, 2000 | 02:41 PM
Polecat's Avatar
I pull mine to 5500 rpms, but it varies so much from engine to engine. Pull to much, you can get valve float, not enough, loose power and torque output. Without a SOLID bottom, I would stick close to 5500.
Good luck!
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Sep 20, 2000 | 02:47 PM
FastBroker's Avatar
You need to make the most torque you can at the highest rpm you can to make the most HP you can. Simple math...
eightsixseven
Dec 16, 2024 01:50 PM
Reddeath210
Oct 6, 2015 08:20 AM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
