Porting plenum
Old Sep 19, 2000 | 03:50 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
Porting plenum
Can I port my plenum with my hand drill and the correct bit, or do I have to buy a Dremel Multipro? Do you think the drill would be to awkward?
Old Sep 19, 2000 | 04:23 PM
rondubbs's Avatar
i did it with a drill and bought a 1$ rasp(used for wood and soft metals) and a sanding stone for 1$,, it worked fine.
Old Sep 19, 2000 | 04:51 PM
Slow88RS's Avatar
you should be alright with what you have.
90 Iroc G92 LB9
Dual Cats, 3.42 B/W, 5spd, K&N, Homemade Ram Air, TPIS Airfoil, 160 Thermo, Mobil 1 Synthetic Oil, Dexco Anti Freeze
3rd Gen Web Site
Old Sep 20, 2000 | 09:40 AM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Thanks.
Old Sep 20, 2000 | 06:09 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I used a "rasp" type drill bit and a drill (the ones we use for GM "knock-outs" to cut down the "walls" right behind the throttle blades and a dremmel to gasket match the runners. You should be OK. I am currently writing a "tech" article including pics. Stay tuned at the link below. Later.
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
If you live in Southeastern US, check us out!
South East Thirdgen
Old Sep 20, 2000 | 06:12 PM
Vader's Avatar
GMT,
Feel free to use anything you can from the following file: Plenum Porting.pdf
I have a few more photos than appear in the article, if you need anything else. I can email *.JPGs of the photos in the file as well.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 20, 2000 | 09:41 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I'll port it for you for sixty bucks.
See the TPI project notes at: http://www.isthq.com/~dan/fcar.html
Daniel Burk
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
New best E/T! 14.400 at 98.6 MPH in 88 degree air at Stanton, Michigan.
Reid Fleming
Oct 10, 2015 09:56 PM
toronto formula
19
Oct 6, 2015 12:27 PM
bplessy
Sep 30, 2015 12:14 PM
