1971 LT1 heads 75cc??
Old Sep 20, 2000 | 06:57 PM
Metallica383's Avatar
Does any one know if these heads are any good I had never heard of the 75cc head but they were rated at 370 horsepowe. How well do you think these would do on a 383?
Old Sep 20, 2000 | 08:33 PM
ede's Avatar
ede
i don't know the cc of the lt-1. but they came with 11:1 pistons so they may of had a larger chamber to make room for the piston dome. you can always get a little milled off them if you need to reduce chamber volumn.
Old Sep 20, 2000 | 08:35 PM
Vader's Avatar
Met,
Get the casting numbers from inside the rocker area, then check for specifications at Mortec.com
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 20, 2000 | 08:39 PM
I already checked the castings and that is what it told me that they were 75cc heads I was wondering if they would work well on a 383 with 10.1 pistons?
Old Sep 20, 2000 | 09:24 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
heads are not given a rated hp nor is a 1971 LT1 a 370hp engine.
Old Sep 20, 2000 | 10:49 PM
These heads were on 1970-1972 LT1 and were on a engine with 370 hp according to mortec so i can believe them or you so Zippy better luck next time i was wanting info not a smarta$$ remark.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Aug 29, 2015 09:51 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
