Non Thirdgen, but in need of help car wont idle, no power
Old Sep 18, 2000 | 10:21 PM
Stell1579's Avatar
ok my friend has a 94 olds achevia. 2.3L SOHC. it wa running ith a slight miss all week comeing and going, now it wont idle, it runs but shakes like hell. like it was running out of gas. if yo ugive it throttle, it smooths right out but in gear has 0 power.
bad vacume leaque? FPR?
thanks
-Stell
Old Sep 18, 2000 | 10:30 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
check ur igniton.... prob need a cap and rotor and new plugs and wires...
Steve
Old Sep 18, 2000 | 10:44 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
should be no distributor cap or rotor on that engine. if i were to bet on it, i'd say head gasket or cracked head. just my input. let us know when you find out.
Old Sep 19, 2000 | 06:18 AM
Stell1579's Avatar
no cap and wires. plugs are new.
if it was the head gaskets ot a cracked head wont it be burning water? (white clouds comeing out of tailpipes?) i am gonna take a good look @it tomorro when i have my day off. if it is something to do w/ head, would a compression guage on each cylender tell me? ie:: 3 of the cylenders read 5psi and one of them reads 1psi (just choosing numbers for example)
-Stell
Old Sep 20, 2000 | 10:50 PM
Stell1579's Avatar
UPDATE!!!
ok i ran it, no power cant climb a driveway and i looked under the car, the cat was glowing red. witch leads me to believe one of the cylenders is out. what could it be, iam gonna run a compression test to rule out, valves,timing belt, rings,headgasket/cracks
if those are all ok, what could it be?
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch
And Always Trying To Go Faster
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
bryan623
Aug 10, 2015 11:33 AM
