Pollution/Smog questions
Old Sep 19, 2000 | 09:32 PM
Iroc_Z28's Avatar
i am sure someone has probably asked this several times but i was wondering how can i take all of my pollution and smog stuff off without keeping the service engine light on...any help is appreciated ...
87 Iroc-Z
350 TPI accel super coil
accel cap and rotor and wires
ads super chip and k&n air filters
future mods include a New paint all new weather stripping and dual exhaust with headers
Old Sep 19, 2000 | 09:56 PM
Vader's Avatar
IROC,
What exactly do you mean by "all the pollution and smog stuff"?
Are you talking about the A.I.R. pump? EGR? PCV? Charcoal canister? Cat converter? What?
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 19, 2000 | 10:22 PM
Iroc_Z28's Avatar
the smog pump and the manifolds because i want to put a regular set of headers on my car...i just want to get rid of all them little pipes or lines running to to them manifolds ....the car doesnt have a cat on it...
Old Sep 19, 2000 | 10:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I ripped off all my smog crap and I dont get any engine lights even though I have the 2 Smog wires just dangeling.
Old Sep 20, 2000 | 11:34 AM
tesla042's Avatar
hehe.. My previous owner ripped the AIR pump off, but left the cat on... The lil connecty frobs that i assume go into the pump were left dangling... a while ago i noticed they had melted to my exhaust manifold! hehehehehe
91 T/A 305
STB, Airfoil, Hooker cat-back, pseudo-cold air to K&N, Accel coil, !cat, !smog pump.
300 lb*ft of rice churning power.
Old Sep 21, 2000 | 12:25 AM
Vader's Avatar
IROC,
If you don't have emissions testing in your area (yet) then you can delete the AIR tubes from the exhausts and install plain headers without causing any ECM problems. You will still need to have the oxygen sensor installed in the exhaust tube set. The AIR pump can also be deleted, and you may or may not have a problem with the diverter solenoid removed from the system. On an '87, I don't believe the ECM looks for a load on those wires, so you should be O.K. You cat converter can still function without the extra air from the pump, and if you install newer high-flow cats, you don't need air injection at all to remain "clean".
Later,
Vader
"Make Me Bad"
Old Sep 21, 2000 | 02:13 AM
Iroc_Z28's Avatar
thanks alot for all the input it is very helpful and greatly appericated
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
