not third gen but chevy
Old Jun 9, 2003 | 08:02 PM
1986redbird's Avatar
Hey guys, My sister has a 96 corsica which has a problem. the SES light is on and stays on, she had a parts store check for codes and they didn't find anything. she said Chevy wanted $50.00 to reset the light, what has to be done to do that, can I do it or does chevy have to?
forgot to mention: I tried unhooking the battery which didn't help.
Old Jun 9, 2003 | 09:46 PM
Vader's Avatar
Depending on the type of error code, you MAY be able to reset the light by disconnecting the battery for a few minutes. If it is a hardware fault, it will reappear as soon as you start the engine or shortly thereafter. If it is a misfire diagnosis, it may clear for a while or permanently. If you don't have the scanner to diagnose the problem, you can try that, but it really isn't a fix, just a "Band Aid".
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
BADNBLK
Nov 16, 2016 09:12 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
