rod knock or spun a bearing?
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
i know that the noise coming from my engine is either a rod knock, or i spun a bearing. how do i know which one it is, and is it somewhat ok to drive until i get my 350 in?
Car: 4
Engine: 6
Transmission: 5
Same thing. A spun bearing is the usual cause of a rod knock. Spun bearing = disease, rod knock = symptom.
If you're putting your 350 in later this afternoon, then yes it's OK to drive until you get it in. Past that, I doubt it.
Car: 1988 trans am
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
i had to drive my rod knockin lb9 from brighton to my house..which is about 50 miles or so
it was an intresting ride though
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
it'll prolly have very little power. the ECM will pull the timing like a mother when it hears the knock. at least that's what mine did.
skinny z
Oct 5, 2015 06:23 PM
