ESC question?
Old Sep 13, 2000 | 09:06 PM
quickL98's Avatar
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
ESC question?
since i have put a 350 in my car do i to switch out my ESC(electronic spark control module) for one that applys to an 5.7L along with the appropriate knock sensor, i was told that the computer wont properly retard the timing if the components arent right, but watching my timing on the scanner it advances and retards accordingly and i havent had any signs of detonation or "knock" he says the computer wont pickup any knocking if the module and sensor arent for a 5.7l ? has any body run into this before? as far as i knew the only difference between the 5.0 & 5.7 computer's for the same year vehc. was the chip...any body ..anybody?
87GTA 355TPI,A4 shooting
for low 12'
Old Sep 13, 2000 | 11:43 PM
Jarod87IROC
Guest
Posts: n/a
I swapped out my 305 for a 350 last November and I still have my stock ESC. And up until a couple months ago I was also using my stock 305 knock sensor as well. I didn't notice any ill effects with either of them. The only reason I changed my knock sensor was because I pulled the old one to drain the coolant while I was swapping my heads and cam and decided to put a 350 sensor in rather than reuse my old one.
In fact, I'm even still using my stock chip and my car runs great. I'm almost positive I'm robbing myself of some extra power but as for drivability I have no complaints whatsoever. I've got a custom chip on it's way so we'll just how much of a boost in performance it gives me.
87 IROC
350 TPI 5-speed
Edelbrock Aluminum Heads, LPE 219 Cam, Super Ram, SS Wheels, Graphite Leather, etc. Click here to see the rest.
THE crew: ICON Motorsports
Old Sep 14, 2000 | 09:56 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Yes - you need to swap your ESC filter (knock module).
I was doing some PROM tuning on a buddy's car who switched from a 305 to a 350. He was using the same knock module and was experiencing an increased amount of knock over an entire WOT run. After switching to the correct Knock module the knock decreased dramatically.
A good example applied to 4th gens is when the 4th gen guys switch to an LT4 knock module. Less knock.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
-=ICON Motorsports=-
Old Sep 21, 2000 | 12:21 AM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I just did an engine swap two months ago, and I was running the car with the stock chip, esc, and knock sensor. I didn't have any problems with the setup except that I wasn't sure how to set the static timing at first on the newer cars. Once I did that, the car ran better. I called up Hypertech and I found out that with my setup, a different chip would get me some better performance. I prodded them for the GM chip # and went to the dealer and ordered that for the car. The car had some more *****, but I also had to change out my injectors. I guess what I wrote all of that for was to say that it isn't neccesary to change the spark control unit...
If you have any questions, drop me an email.
-mike
Old Sep 21, 2000 | 06:07 AM
Chuck Everly's Avatar
quickL98, I am moving this to the General Engine forum. I think more people could benefit from this post in there.
Old Sep 22, 2000 | 01:06 AM
Hunter Motorsports's Avatar
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
Hey Trax - When you refer to the "knock module" are you talking about the sensor in the coolant drain hole in the block, or are you talking about the ESC module which is up on the left hand side of the firewall? your terminology is a little confusing cause the S.D. cars (90 - up) do not have an ESC module, so I assume you are talking about the sensor?? Please enlighten me. Thanks
Karl Hunter
Hunter Motorsports
Vancouver, B.C. CANADA
GTAman
Sep 21, 2015 09:57 AM
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
