popping from exhaust/rough idle
Old Sep 22, 2000 | 09:38 AM
Tab92bird's Avatar
Yes, I've posted this before, and I'm sorry I'm bothering you poor people more than I already have, but I have updates.
1. O2 sensor is fine; put in a new one and there was no change.
2. EGR valve is ok; ditto above.
I'm going to pick up some new plug wires today or tomorrow, but after I do this I'm totally stumped. I'm afraid I will have to resort to taking her to a shop.
I have another idea, though, so anyone with headers help me out here: is it possible that I need a heated o2 sensor? I have the heddman shorties and the o2 bung is a few inches from the the collector.
Thanks,
Brandon
White '92 Firebird w/ 305 TBI. Open element w/ non drop base, increased fuel pressure, TBI spacer, Hedman Hedders & y-pipe, no cat, cat-back exhaust
Old Sep 22, 2000 | 12:51 PM
Vader's Avatar
TAB,
Popping exhaust can be from late ignition timing, and overly rich mixture, leaky/hot exhaust valves, or excessivly late valve timing (slipped timing chain).
A heated O2 sensor never hurt anyone, but having yours mounted right at the collector with shorties shouldn't be making for a cold sensor. Are your headers coated?
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 22, 2000 | 01:10 PM
Tab92bird's Avatar
no, they are not coated. One reason I suggested the heated o2 sensor is because when the stumbling starts, sometimes the ecu will go into open loop momentarally. BTW, I just changed the wires, and they weren't the problem .
Old Sep 22, 2000 | 09:23 PM
Tab92bird's Avatar
btt
Old Sep 23, 2000 | 01:27 AM
Tab92bird's Avatar
please please please please please (refering to Kids in the Hall)
Old Sep 23, 2000 | 03:02 AM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
my car does the same thing - but i was woundering how your power situation is - I had my engine replaced when i put my headers on and ever since my car has been making no torque at all and probibly less than 170 hp when i had it at 250 hp verified by a dyno before the engine and headers - and like you im stumped - I've replaced everything now except the injectors - so im convienced it either one of them or something wrong with one of my heads
Old Sep 23, 2000 | 10:30 AM
Tab92bird's Avatar
Well, my pessimistic dad thinks it might be a burnt valve, but I don't have any loss of power and the problem goes away after 1000 rpms. Maybe a compression test would help us?
Thanks,
Brandon
db057
Apr 28, 2019 07:45 AM
Stroopwafel
Sep 11, 2015 06:38 AM
Randomtask2
Sep 10, 2015 08:37 AM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
