how EXACTLY do I use a vacuum tester?!
I think I have a vacuum leak somewhere. Although, I cannot seem to locate it. I was going to goto AutoZone and use there tester. I have read that at an idle, it should read between 18-20 inches or pounds or something
Do I just unhook the vacuum line somewhere and plug the tester in? Where is the best place to unhook the line at? Anything else helpful that I should know?
-Thanks
Do I just unhook the vacuum line somewhere and plug the tester in? Where is the best place to unhook the line at? Anything else helpful that I should know?-Thanks
Car: 4
Engine: 6
Transmission: 5
That's it. But it won't tell you whether you have a vacuum leak or not.
Best way to find one is first a good visual; look at every line and fitting carefully for cracks etc. Then to find leaks around carb base gaskets or such things, squirt a small amount of carb cleaner at the gasket and se if the engine RPM responds at all. If it does, the gasket is leaking, letting in the fuel.
Pac J
May 17, 2020 10:44 AM
HoosierinWA
Oct 7, 2015 10:15 AM
