valve springs?
valve springs?
What is the most affordable but compaitible springs for a ZZ-4 cam in a l98?
88 black gta
tb coolant bypass
gutted maf
gutted air boxes
no cats or smog
700r with a snior citizen discount
bald tires
88 black gta
tb coolant bypass
gutted maf
gutted air boxes
no cats or smog
bald tires
Mike,
Umm, what about, oh, maybe LT4 springs?
They are designed specifically for use with the LT4 "hot" cam grind, so I guess you can't get any more compatible than that. The LT4 "hot" has just a bit higher lift numbers than the ZZ3/ZZ4 cam profile.
You'll need 16 pieces of GM P/N 12551483 for about $4.85 each, or save some cash and get the valve spring kit, P/N 12495494, which already contains 16 springs for about $35.93
You'll also need the appropriate caps (retainers), P/N 10212808, or order the 16 piece set for $15.54, P/N 12495492. To complete the parts list, get the matching keepers, 32 piece set for $6.83, P/N 12495503.
The springs are made of oval wire, and will require some head machining to accomodate their larger outer diameter (1.3415"OD x 0.901"ID, 2.150 Free height, 101 Lb@1.780" 0.217"x0.180" wire).
The retainers are lightweight steel, 14.45g each.
They are conservatively rated at 0.525" gross valve lift, and for less than $60.00 for the whole set of parts (other than screwed studs, if you don't already have them), you can't beat the price for a GM part.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
[This message has been edited by Vader (edited September 21, 2000).]
Later,
Vader
"Make Me Bad"
What is the cheapest place to get a ZZ-4 cam?
Every catalog has them for around 269 bucks, but if you can get the whole spring set for 60 shouldn't the cam be cheaper as well?
Any one ever bought or used the ZZ-4 cam?
Mike,
You can also get a complete LT4 "Hot" cam kit from GM, with springs, retainers, etc.
Later,
Vader
"Make Me Bad"
Later,
Vader
"Make Me Bad"
LT4 hotcam kit part#12480002 $475.30,includes cam,1.6 roller rockers,springs,caps,valve keys,and shims.LT4 spring kit (used on ZZ4)part#12495494 $25.13.www.gmpartsdirect.com
We need Perry Mason
We need Perry Mason
