How much improvement with 6" over 5.7" rods in a 383?
Old Sep 23, 2000 | 12:03 PM
crazeinc's Avatar
I can get a very nice deal on some 5.7" rods, but I was really thinking about putting 6" rods into my 383 this winter...should I be smart and go with the good deal because I don't have a lot of money to begin with or is there huge amounts of improvements with the 6" rod?
I won't see any problems with a 5.7" rod with a 400 crank correct?
82 Z28
355 carb'd, Edelbrock Performer RPM package (minus heads), Hooker Super Comps, Mufflex 4" offroad y-pipe, 700r4 with B&M shiftkit, '85 IROC 10 bolt rear with Richmond 4.10's & Auburn posi unit, Lakewood 50/50 drag shocks. Shooting for 3000lbs w/ driver.
The car's website
(383 buildup this winter)
AIM: Unitedhope
ICQ: 77979548
Old Sep 23, 2000 | 12:05 PM
crazeinc's Avatar
I should also add that I plan on a 6000-6500 redline and torque and hp somewhere in the range of 450...
Old Sep 23, 2000 | 02:17 PM
calroc's Avatar
Go with the 5.7" rods, especially if you're getting a deal. I've done both. Piston selection is plentiful for the 5.7 rod/stroker, and priced MUCH better. Custom pistons for a 6" rod stroker will numb you.
I'm not sure about the performance gains with the 6" rods alone, because I changed alot of other things when I went from the 5.7" to the 6.0" rod, but I'll wager it's not worth the price of the pistons for the 6.0" rod alone.
85 calif. iroc
383/A4
9" rear
Old Sep 23, 2000 | 03:41 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
When using anything longer than 5.85 on a 3.75 stroke motor, you end up having the oil ring supported by a insert (at the wrist pin area) because the wrist pin has been moved up soo high.
Old Sep 23, 2000 | 07:33 PM
82camaro's Avatar
Car: 82 camaro SC
A 6 inch rod will help reduce high rpm stress. This is really important if the high rpm is sustained for long periods of time--like circle track. If money is no object I would do it. For a street/strip engine, I would think twice about the 6 inch rods because of the cost.
As far as power improvement, you may see a little, but not much.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Sep 23, 2000 | 08:16 PM
crazeinc's Avatar
that settles it then, 5.7" rods for me
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Ed1LE
Sep 30, 2018 09:14 AM
wanext
Oct 6, 2015 12:18 AM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
