whats the difference???
Old Jun 16, 2003 | 04:21 PM
daddy33's Avatar
Car: '85 Camaro
i just got my 350 block bored .040 and im looking for a set of pistons. I saw some flat top pistons and some domed pistons. What is the difference between them two? (i know one is flat and other is domed so dont act smart) Anyways i wanted to know which one is the best one to go with? Do different ones change the compression ratio? anyways i was just curious about this before i went out and bought some pistons. Thanks guys
Old Jun 16, 2003 | 05:49 PM
dave89gta's Avatar
You hit the nail on the head. Domed pistons will give you more compression than flat top pistons. Before buying, I would double check you combustion chamber size, to make sure that you maintain a streetable CR, if thats your goal. Also check to make sure that you will have sufficient piston to valve clearance, because that could make a mess.
--Dave
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
