water pump question (long or short)
Old Jun 16, 2003 | 05:31 PM
cerice's Avatar
I am getting ready to put a GM ram jet 350 motor in my 89 iroc. I was checking to make sure the serpentine pulley set from the car would fit the same on the ram jet. However, the bracket with the power steering pump and alternator will not bolt up because the power steering pump hits the water pump. The ram jet comes with a long water pump. My question is does an 89 350 motor have a short water pump. I purchase the car without a motor, so I have nothing to go by.
Old Jun 16, 2003 | 05:44 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
It's my understanding that our cars came with long pumps.
Old Jun 17, 2003 | 07:57 AM
Vader's Avatar
I understand that about the only auto engines that came with a short pump after the mid- to late-'70s was the Corvette. Maybe the trucks had them in some installations, however. But if it helps your clearances or accessories, go for it.
Old Jun 17, 2003 | 06:02 PM
cerice's Avatar
What I am hoping is that the water pump make for the the 89 iroc camaro was designed so there is not a clearance problem. That will be the next thing that I do. I bought the car from a buddy of mine, and he has an edlobrock water pump for an 89, which I will try an bolt it up to the ram jet motor and see if that works. If not I may decide to go with a different pulley set up, or possible fabricating a difference bracket.
Thinks for the help.
Old Jun 18, 2003 | 12:32 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
The water pump on a '88 TPI 350 with serpentine belt is reverse rotation. I've never had clearance problems with the brackets or the aluminum aftermarket pump, or the correct cast iron pump on a few different serpentine setups.
It doesn't have the mounting studs like the normal rotation long water pumps and it is the long pump. Actually, you can change the water pump without removing any of these brackets too.
That's how it's worked for me anyway.
Old Jun 18, 2003 | 07:27 AM
cerice's Avatar
That is what I am thinking. Once I take off the water pump that came on the ram jet 350, and get the correct water pump for the 89 set up my pulley clearance problems will be solved. Thanks for the help.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Street Lethal
Aug 12, 2015 11:33 AM
