Any distributor guru's out there????
Old Sep 24, 2000 | 09:46 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I have a computer advance distributor. I was wondering what the stock intial timing and total advance is? I don't know if all computer controlled distributors got the same timing or what but the computer controlling it is for an 86'Z28 LG4 305. Can these be tuned for performance?
1986 CAMARO Z28 -> 150,000 original miles, 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> LCA lowering brackets, homemade ram air, B&M shifter, AFR 195 heads, 234/234 cam, Weiand stealth intake.
Old Sep 25, 2000 | 03:19 AM
Justy's Avatar
The only way to "tune" your computer controlled distributor for more advance is with a performance chip for your computer. Sad but true.
Old Sep 26, 2000 | 01:11 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Would I be better off getting an aftermarket one? Would a stock replacement vacuum advance one work ok? The engine isn't going to go over 6500rpm. Do you know how to tune these? I was told to get a spring kit and use a medium and a light springs. What should my intial timing be? What should my total advance be? The engine is 9.5:1 compression, stock 89' corvette cam, and 89'F-body cast iron heads. My upgrades are listed in my signature I posted below.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
