Bogging
Old Jun 18, 2003 | 05:08 PM
T-Top T/A's Avatar
Car: 85 Trans Am
Engine: 305 LG4
Transmission: 700-R4
Axle/Gears: 3.08
Bogging
I have an 85 TA with the 305 LG4 motor.my problem is, when Im stopped at a light or whatever,when I give my car gas to go, It bogs down real bad. If I punch It, It almost stalls and then takes off spinning the tires. I had the carb rebuilt with a new tps,changed the EGR valve(GM), and changed the plugs/wires. what could this be?? the only thing else I can think of is the fuel pump. any info will help! thanks
Old Jun 18, 2003 | 09:56 PM
Killogy's Avatar
Car: 87 Firebird Formula
Engine: 355
My old LG4 used to do that too. Mine was caused by the air valve on the carb sticking open. So I'd go to take off at WOT and it would like stall out, then take off real fast. Don't know if this is your problem or not.
Old Jun 18, 2003 | 11:51 PM
T-Top T/A's Avatar
Car: 85 Trans Am
Engine: 305 LG4
Axle/Gears: 3.08
thats exactly what mine is doing! can you give more info. on the air valve, where is it on the carb? how did you fix It?
Old Jun 19, 2003 | 03:38 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hey you guys are both from CT, cool me too, the air valve is the plate on top of the carb that opens.
Old Jun 19, 2003 | 04:28 PM
T-Top T/A's Avatar
Car: 85 Trans Am
Engine: 305 LG4
Axle/Gears: 3.08
yea, this looks like a CT thread. so the air valve your talking about is the choke (closes when cold, opens when hot...) I thought thats suppose to be open when running?? I noticed when I first start it when cold ,it revs up to like 1800-2000 RPMs, and I cant get it to kick down. Im bringing it back to the guy who did my carb tomorrow. thanks guys
Old Jun 19, 2003 | 11:10 PM
Killogy's Avatar
Engine: 355
Air Valve is the flap right behind the choke. And the choke should open if you push the gas pedal all the way to the floor and let off real quick.
pjsparts
Oct 29, 2025 06:39 PM
RedLeader289
May 28, 2019 01:47 PM
Infested
May 22, 2018 11:56 PM
Grant2k
Apr 4, 2016 08:21 AM
middian
Sep 5, 2015 01:42 AM
