MSD 8.5mm wire fit 8mm wire looms?
Old Jun 18, 2003 | 11:53 PM
llvll4l2c91350's Avatar
i have a set of Made for You centerbolt 7-8mm wire looms. am looking to buy the 25 ft bulk wire from MSD and the 90* boots. however the wire is slightly thicker than what the loom can hold. would this be a problem or can i make 'em fit without crushing it too much?? anyone using this setup? i wanna be sure i can use 'em before i order. thanks.
Old Jun 19, 2003 | 02:11 AM
25THRSS's Avatar
you could always drill them out slightly larger.
Old Jun 19, 2003 | 10:22 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I have had these for about 2 years..they are for the 8mm wires and Im fixin to go with some 8.5's I dont see why they wouldnt fit...you just wont be able to screw down the looms all the way...
Old Jun 19, 2003 | 10:28 PM
in that case they should fit. i forgot the looms had the screws thru them
i ended up ordering the 25 ft bulk wire set, along with 10 pairs of boots. hopefully they'll be here by saturday.
BRoss99
Aug 10, 2025 05:08 PM
toronto formula
Nov 10, 2015 06:17 AM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
