Question about adjusting the IAC...
Old Sep 25, 2000 | 10:29 PM
Drowned's Avatar
Quote from tech article:
Take the paper clip and open it up and form it into a big "U" shape. Insert the clip ends into the ALDL in the 'A' and 'B' pins.
Turn on the ignition, but don't start the engine. Wait 30 seconds. Now, go remove the connector from the IAC.
Start engine.
I just have to make sure about one thing. I have to remove the clip from the ALDL before starting the engine, or it will screw up my ECM, right?
Old Sep 26, 2000 | 12:42 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
To verify that the throttle plate screw is adjusted such that the car will not idle with the IAC seated (closed), you may remove the paper clip across the ALDL terminals. Starting the engine with the terminals shorted will not harm the ECM, it will run the ECM in diagnostic mode - the check engine light flashes according to the mixture ratio, etc.
Tim
Old Sep 26, 2000 | 11:15 AM
Blade's Avatar
So to sum it up YES you would have to remove the paper clip before starting your engine.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Sep 26, 2000 | 05:53 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
Take out the paper clip before starting
1986 TPI 305 TRANS AM
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
deracer
Apr 11, 2016 12:04 AM
86IROC112
Aug 21, 2015 12:39 PM
redmaroz
Aug 16, 2015 11:40 PM
