codes 33,34 and 45
Old Sep 26, 2000 | 05:59 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
codes 33,34 and 45
can someone help, i know the tps is a little low, but if i put it at 54 or above it will start then turn off, any suggestions
1986 TPI 305 TRANS AM
Old Sep 26, 2000 | 06:56 PM
snakeskinner's Avatar
ok, I'm confused because your title and message do not correspond. what does the TPS have to do with MAF codes? I know modifying the TPS pivots can cure some code 33 situations but if you have both, I'd look for a bad MAF. I am unsure what code 45 is off the top of my head. Kyle
Old Sep 26, 2000 | 07:04 PM
Vader's Avatar
Tom,
You have the unusual circumstance where the MAF is actually sensing too much air entering the engine at a given throttle angle. Most of us get a 34 alone and end up replacing the MAF. In your case, I'd replace the TPS and adjust it to 0.54VDC dead-nuts.
I'd also get a replacement PROM for the ECM, since the original PROM delivered from the factory has some programming errors. Check the "TIPS" section at the 3rd° web site for details on the problem and the solution. I'm glad I did...
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
