What is causing my backfire????
Old Jun 19, 2003 | 10:58 PM
CamaroX84's Avatar
Setup is in the sig. Ok, well occassionally the car will backfire through the intake when I come off idle, and I never really thought of it as an issue (I figure it needs a bigger accelerator pump nozzle). I've noticed now that when I floor it from a dead stop, the car will pull fine all the way through 1st and 2nd gear no problem, but as soon as I shift into 3rd, it backfires through the intake a couple times in a row. As soon as I let off the gas, it's fine. My jetting is the stock 76 and 82. Timing is set at 15 degrees initial, and 36 degrees total. Normally I would guess that an intake backfire is caused by a lean condition, but I'm boggled because it only happens consistantly in 3rd gear. Any ideas??? Thanks in advance.
Old Jun 20, 2003 | 05:03 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
hmmmm dist 180 out? thats my only guess.........
Old Jun 20, 2003 | 08:25 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
this probably isn't the problem, but a problem you could have if you haven't already.
Your power valve blew out in your carb. One backfire and it could blow it out, but it would backfire alot. but worth checking into.
Old Jun 21, 2003 | 12:26 AM
CamaroX84's Avatar
Thanks for the replies. It's a demon carb, and don't they have power valve blowout protection??? Thanks.
Old Jun 21, 2003 | 12:30 AM
CamaroX84's Avatar
Forgot to put this in my last reply...Now it seems to do it everytime I floor it. And today after a 10 minute drive, I shut off the engine, and it "dieseled" on my. The engine was dead for a second, then ran for a second on it's own with the key in the off position!!! Any more ideas?? Thanks for the replies.
Old Jun 21, 2003 | 08:00 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I would go up 2 sizes on your shooters and see if that helps the backfire. As for the dieseling, how far open are your throttle plates at idle? What is your idle speed? I find it odd that the car was running fine and just started to do this, but those two things are where I'd start.
Old Jun 21, 2003 | 12:23 PM
CamaroX84's Avatar
Well, I hooked up a vacuum gauge today....it's only pulling 7 inches in park!! It was pulling around 12 before in park. The car won't even run now in drive unless I double foot it and have the throttle open a little. So I'm definitely guessing a vacuum leak is causing all this mayhem. Thanks for all the replies.
Old Jun 22, 2003 | 12:25 AM
CamaroX84's Avatar
Just found out it's no vacuum leak. The timing was way off. It was sitting at about 2 degrees retarded. I knocked it back up to 15, and the car runs fine now. The distributor bolt came loose. Anyone have any tricks to keeping that bolt tight? I know it was snug when I put it in. Thanks again for the help.
Old Jul 28, 2003 | 07:52 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
are you using a chrome dist hold down? I had one and it just bent when I tightened it down. I went to a orginal gm.
I am having the same problem, I have checked everything. I just cant find the problem.
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
