maf
Old Jun 21, 2003 | 04:59 AM
jodylee8310@aol's Avatar
maf
does anyone know the correct readings on the maf connector
Old Jun 21, 2003 | 06:03 AM
kevinc's Avatar
Car: 1982 Z28
Re: maf
The correct readings on this and the other things you posted about are the Helms manual, available from helminc.com
Old Jun 21, 2003 | 09:06 AM
Vader's Avatar
Again, are you asking about output signal or resistance?
Old Jun 21, 2003 | 08:21 PM
maf
i was looking for both to test
Old Jun 22, 2003 | 08:28 AM
Vader's Avatar
Unless you are testing the MAF wiring harness for grounds, shorts, or opens, resistance tests are mostly useless. About the only thing meaningful you can check is for ground resistance at the 'A' and 'B' terminals.
You should get 12VDC at the 'E' terminal while the ignition is on, and 0V at the 'D' terminal. Here is the circuit:
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
