400 cam choice
Old Jun 21, 2003 | 05:12 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
400 cam choice
Okay, I just had another poston things like rod length, piston choice and all that jazz. Now I need to figure out what kind of cam to run. I called Comp to get a suggestion and got the part # 12-560-4. Looked that up on summits website and they show it as a Nitrous cam. I didn't say anything about nitrous and I'm definately not building the engine soley for enormous n20 shots. Anyone have suggestions for street driven 87 bird with a t56 and 3.27s?
Forged flat tops
manley h-beam rods
aluminum dart heads, 200cc runners and 72cc chambers ~9.9:1 cr
under a tpi setup, upgraded injectors and runners
1 3/4" headers and single 3" exhaust.
I'd like to rev alittle bit maybe 6-6.5k or so. But whatever can make the power.
Any help?
Old Jun 21, 2003 | 07:07 AM
ede's Avatar
ede
stock tpi? you'd have a hard time seeing 6000 rpm reguardless of cam, heads or anything else.
Old Jun 21, 2003 | 02:26 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: 400 cam choice
Originally posted by iansane
under a tpi setup, upgraded injectors and runners, etc
I realize stock tpi hardly breaths past 4800 let alone 6k...
Old Jun 21, 2003 | 02:43 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Use the xe268 and get a stealth ram.
Old Jun 21, 2003 | 11:00 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
The nitrous cams are ground with extra exhaust duration to scavenge the additional exhaust gases that the NOS generates. I'd guess that the Comp Cams tech recommended the 12-560-4 to work with the 400's big cylinder to help clear all the exhaust out, not so much to work with NOS.
The 12-560-4 also has a wide lobe separation angle of 113 degrees that will work with the computer better to maintain a decent idle. That cam is pretty hot after all, 224/236 degrees at 0.050".
I think it's these two characteristics that make it work with NOS as well as a big cylinder under TPI induction. I think it's a good choice, it will make more torque & midrange HP than you can likely put to the ground!
Jorlain
Oct 8, 2015 01:57 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
