gauge cluster replacement
Old Sep 27, 2000 | 07:27 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
I'm considering upgrading my gauges
from 185km/h to the 240 (thats 115mph and 145
mph for all you yanks).
Has anyone ever done this? Any tips or advice? Do I need any different parts?
Thanks.
Also, how do I get the right millage
on the new odometer?
88 IROC the best RS ever made!
well except for the BC4s
[This message has been edited by 871LEIroc (edited September 27, 2000).]
Old Sep 27, 2000 | 07:40 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Well, down here, you can either forward the mileage, or right the old milieage on the door frame in a permenent way. As for the swap, i think you'll just need to find a cluster from the same year or newer. i think in 88 is when the camaros finally got the plug in dash gauges... firebirds had them in 86 and newer, which is why my 88 formula gauges went into my 86. there shouldnt be any special tools needed...
Steve
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat, Coming mods: GOT A 350 IN THE WORKS BABY! gonna throw my TES edlebrock headers on it, and hopefully get some more gear and the cowl hood on
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
Old Sep 27, 2000 | 08:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you unscrew the faces of the speedos to give yourself some room, you can pull the clips holding the odometer shafts and swap them.
1984 Silver Z28, 383 cid long-rod 4 bolt SBC, ARP Bolts, 2 1/2" Cowl w/ Cold Air Induction, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Roller Tip Rockers, MSD6A Ignition, Blaster2 Coil, HEI Distributor w/ Adjustable Advance, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flowmaster Muffler, 4 Wheel Disc Brakes, Oil Cooler
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
