so i broke the insulation from the back of the alt
Old Jun 21, 2003 | 10:15 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
to the wire that goes to the battery so it now it sparks when they touch.
What can i Put back in between them so it doesn't spark.
Old Jun 21, 2003 | 10:25 PM
Adam87iroc's Avatar
This happened to me also, I was told that the stock wire is too small, and this makes it hot and the insulation brittle. I replaced the wire with a battery cable that I cut the connections off of, jammed it into the alt. and fusible link real good and wrapped the connections nice and tight with high temp. elecrical tape. Worked fine for me.
Old Jun 21, 2003 | 10:33 PM
StangKiller's Avatar
You don't have to rig it, rigging usually ends up failing at the worst times, it's easy to take the alternator apart and put a new insulator in it.
Old Jun 21, 2003 | 10:41 PM
Adam87iroc's Avatar
If you follow killers advice, I would still replace the wire with a higher gauge as the stock size always caused me to have charging problems.
Old Jun 21, 2003 | 10:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you are talking about the 'cover' that goes on top of the two wires that are on the back and held down by a nut, just look for the rubber cover from an older one (like what came with my '79 350)
Its rubber, so it doesn't break and wont allow any arcing (sp?).
Old Jun 21, 2003 | 11:26 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Im talking about the one wire on the back of the alt.
I just need to stick something around it so it doesn't spark?
I can't even get the bolt off the back. it just spins when i try.
so i need to rig it up.
I need to like tie something around between the nut and alt.
Old Jun 22, 2003 | 12:00 AM
Adam87iroc's Avatar
See my 1st post,
the same thing happened to me.
Tape a wire in there and shop for the rubber connecter that was suggested earlier. I am good with the high temp tape, just fix it so the volts flow without a bunch of heat.
Wylecoyote08
Nov 6, 2015 03:46 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Jae992
Aug 27, 2015 09:07 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
