Finishing up on the serpentine swap
Old Jun 22, 2003 | 06:47 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
http://elite-fraggers.org/sonarun/Tr...entine%20Swap/
Anyone know where I can find weatherpack connectors locally? The guys at AutoZone and Oreilly's didn't even know what they were..
Old Jun 22, 2003 | 08:21 PM
ronterry's Avatar
Car: '94 Corvette
Pepboy's carry Weather Packs, but you better bring your big Visa.
I remember throwing out 18 or 19 bucks for a simple 6 wire.
Ron
Old Jun 22, 2003 | 08:35 PM
Sonar_un's Avatar
Car: '86 T/A
I don't need anything that elaborate.
Since I did the swap, the connectors are slightly different. I need..
2, 2 wire connectors for Smog Pump
1, 2 wire connector for A/C
1, 4 wire connector for Alt (that one only uses 2 of the 4 connectors.. wierd
The thing is, they all need to be the right connectors. Hmm
Old Jun 22, 2003 | 11:20 PM
ronterry's Avatar
Car: '94 Corvette
Yea, I would check the online stores first - like Summit or what not.
I've seen two types for the GM, aside from the male/female. They had one you solder the wires to the contracts in the pack, and one that had it allready assembled with about 6 inchs of wire per contact. With packs from 1 wire all the way to 6 wire... again at Pepboys...
Now, on the other hand I've also seen specific aplications like you mentioned. There's a very limited supply of these at Checker Auto & Pepboys.
Ron
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jharrison5
Aug 19, 2015 05:53 PM
jahblah
Aug 12, 2015 05:54 PM
