What Cam + other quick question, l98 350
Old Sep 28, 2000 | 06:11 PM
noam's Avatar
I'm ordering the Edelbrock Performer RPM 64cc heads for my 91 Z28 5.7L 350 L98.
I figure, while i'm at it, might as well get a cam to go with it, im torn between two cams, and i want to find out
a) that they are the right ones im looking at
b) which one do i want
I'm looking strictly for speed and street legality with this car. It has a well built tranny that will hold up to the power, im HOPING the rear will too but im not 100% sure, the only other thing i'm not thinking of I think is the possibility of needing a new ECM, if there's anything else i'm forgetting please tell me. Ok idle would be nice but eh, cant have it all. But here's my 2 choices right now.
Comp Cam 268H 218/218 duration, .454/.454 lift.
SLP Cam SLP51010 224/230 duration, .502/.510/lift.
The SLP cam is like twice as much as the Comp cam i know but eh, if it's worth the power it's worth the power. I thought about the LT4 HOT Cam but i dunno, i heard good/bad things about it. If anyone has any other suggestions for cams, or has a pick for the cam they would choose, i'd appreciate it.
My other question(s) is this: who makes a good rebuild kit for this motor as it has 113k on the odometer, how much is it, and where can i get it (i've seen a few in summit).
Old Sep 28, 2000 | 08:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Isn't that Comp cam a flat tappet? The SLP is a roller. You really ought to go back with a roller.
Check Comp's grinds for the 87-up motor, look at the ones with grind # like 12-304-14. I can't get to their page right this minute, but I think that's about a 264HR, it's about 218/228 (you will benefit greatly from a dual-pattern with bigger exhaust with those heads) with somewhere near .500" of lift.
Don't get the regular 268H flat, it's the totally wrong design for a modern FI motor. If you're determined to go flat use the XE series cam instead, and have them grind it on 113° or 114° lobe centers instead of the catalog 110°.
Old Sep 28, 2000 | 11:06 PM
noam's Avatar
bah, i think i'll go with the SLP cam anyway, they're about 5 miles from me hehe, save on shippin and stuff.
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
