Idles rough..why?
Old Jun 23, 2003 | 07:53 PM
H22T/A's Avatar
Idles rough..why?
whats wrong with my car?..while idling the car shakes alilttle, when it is in gear and calms down in park or neutral, also after cruising and stopping at a stop light i can smell either gas/smoke coming in my car, if i leave the windows open. My car is idling at 6-700 in neutral/park and 500 in drive.
I cleaned the points on the distributer and cap, new spark plugs and wires, good alternator, and im checking the timing timing tomorow..also i found out my ac/heater fan doesnt work and my a/c compressor doesnt kick in when i turn it on is this associated with the problem??.if u have some info on this please post
btw its a 84 transam 305 auto
Old Jun 23, 2003 | 08:49 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
you might find out taht your timing is out of whack. Seems like a timing problem however.
What kind of carb if at all do you have? or tpi?
Old Jun 24, 2003 | 01:37 AM
jodylee8310@aol's Avatar
check out your purge valve on your vacuum canister as well
Old Jun 24, 2003 | 04:32 PM
H22T/A's Avatar
it's a 4barrel quad..imma check the timing tonight and also the purge valve// thanks
Old Jun 25, 2003 | 08:22 AM
Vader's Avatar
Check teh timing. Clean the carb. Check the TPS voltage (should be 0.48VDC). Check the MC solenoid operation. Make sure the oxygen sensor is generating a signal. Scan for error codes.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
