need help with TPS sensor
Old Jun 23, 2003 | 08:13 PM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
i had a weird problem i changed my TPS sensor for a new one and heir was nothing wrong with mine but i changed it anyway.the problem is since i changed it i cant get back into spec i tried 2 nw ones one from advanced auto and one fron nappa i couldnteven get them to go any lower than 2.40 volts i now put hold one on and the closest i can get is 0.40 volts but it still idles to high could their be something else causing this? o yeahi reset the pc it didnt help.
Old Jun 24, 2003 | 07:30 AM
Vader's Avatar
the closest i can get is 0.40 volts but it still idles to high...
If you're at 0.40V, all you need to do is adjust it up a bit to 0.54V. Idle RPM is not directly controlled by the TPS voltage. The throttle stop screw position and IAC control the idle RPM.
Old Jun 24, 2003 | 09:26 AM
1987gt's Avatar
Car: 1989 GTA
i know i allready have it up as far as i can the best i can get out of it is 0.40v and the idle does change when you mess with the TPS though.it used to idle perfect before i messed with it so i dont believe its the IAC.
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
bbsr72
Apr 2, 2016 09:12 AM
Fred SS
Oct 12, 2015 11:27 AM
BWilcox
Sep 20, 2015 12:19 PM
