Knocking sound... ARGH!
Old Sep 29, 2000 | 08:33 AM
Alan84TA's Avatar
Just got a '85 TA and noticed when you start it up from being cold there is a knocking sound.. car only has 63k on it.. almost sounds like its comeing from the transmission tunnel though.. quits after about 15sec or so... speeds up if I give it gas, and doesn't do it when its already warm... please tell me its not a rod knocking, I think I'll cry....
Old Sep 29, 2000 | 12:53 PM
Vader's Avatar
Hey EdE! I'm not gonna tell him, are you? EdE "I'm not telling. How about you, Karp?" Karp"I'm not telling him. Hey, let's get Mikey. He'll tell him anything."
Hey, Mikey!
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 29, 2000 | 01:12 PM
hdtripp's Avatar
Car: 89 Formula
Engine: 5.0L tpi
Transmission: 7R400
Alright, I'll bite. This may be a stupid question ( I thought there were none), but my Formula has had a small knocking sound (almost sounds like the old heat risers) for at least three years. It has nearly 200k, and it only does it when it is cold. Is this a rod knock? I thought it first it was, and waited for the inevitable, but has not happened. I got the car when it had about 95k, and noticed it soon after. I have had it since '95.
H.D. Tripp-89FormulaWS6 w/5.0L TPI, Street & Performance Chip
Old Sep 29, 2000 | 02:13 PM
1984 Z28 BlackGold's Avatar
HDTRIPP: What you are talking about is PISTON SLAP....the piston wobbles in the bore until it expands & quiets down....4th gen LT1's are noted for this.
Alan 84TA: I had a Monte Carlo that had a rod knock....it knocked ALL the time. You may have worn main bearings...when you start it, there is insufficient oil pressure to "Cushion" the crank/bearing surface.....A friend of mine has used SLICK 50 on two different occassions & swears that he no longer heard the knocking upon startup......I do not believe in the "Engine rebuild Kit in a bottle B.S...but with your low mileage, I'd give it a try.
Good luck,
Roy
1984 Z28 Black/Gold
385 Horse 355
4 Bolt Block, Steel Crank, Forged Flat-Tops
Vortec Heads
Performer RPM
Edelbrock 750
Xtreme Energy 268
Noisy Gear Drive
7 Quart Oil Pan, High-Volume Pump
Hedman Full Length Headers, Crappy Custom Y Pipe..2.5 Flowmaster..NEEDS IMPROVEMENT
700R-4, Shift Kit
3.73 One Legger Rear
265/50/15 Rubber
145 Mph Speedometer
SSM Subframe Connectors
Not Environmentally Friendly
1986 Trans Am
Stock 350-4 Barrel, 5 speed, 3.23 Posi, 16" Formula Wheels, T-Tops, 4th Gen Leather seats
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
