Fuel Pump Pushrod with a Roller Cam
Old Jun 24, 2003 | 07:35 AM
Wheels's Avatar
Hey
I have an 87 motor that does have a boss for the fuel pump and it even has a hole in it. This was a TPI motor and I am going back to carb. It also has a roller cam! Can I just use a regular fuel pump pushrod or does it have to have a brass tip or something? I am assuming I need a brass distributor gear so I thought this might be the same thing?
Thanks!
Old Jun 24, 2003 | 08:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes it has the lobe.
No you don't need a special fuel pump rod. A 87 LG4 car for example has a mech fuel pump with an ordinary rod.
You don't need a brass gear on the dist. Look at the one that's in there, you'll see it's not brass.
Old Jun 24, 2003 | 10:10 AM
Wheels's Avatar
More
Cool! Thats just one less expensive part I need to buy!
On the distributor though I think I may? The one in there wasn't but I think the guy that built the motor was not the brightest so he may not have known. I thought roller cams were softer and therefore had to have a brass gear?
Old Jun 24, 2003 | 10:15 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No.
Racing rollers (and billet flat-tappet cams for that matter for real racing) are very hard, and therefore require a softer dist gear. The design of the system is such that it will not work if there are 2 very hard metals; one must be soft. Factory rollers, and virtually all aftermarket hydraulic street rollers, are soft cast iron just like typical stock cams.
Old Jun 28, 2003 | 12:52 AM
jimfulco's Avatar
Car: '72 Nova
Transmission: Saginaw 4-speed
What about the factory "melonized" distributor gear? What is melonizing anyway?
Old Jun 28, 2003 | 07:03 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Works fine.
Glowsock
Jul 24, 2025 03:15 PM
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
anesthes
Aug 8, 2015 09:37 PM
