code 22 & 32 please help
Old Jun 24, 2003 | 04:22 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
i checked the engine service soon light and i got code 22 and 32 now what?
Old Jun 24, 2003 | 07:20 PM
Vader's Avatar
Check this file for code explanations:
GM Error Codes.pdf
Old Jun 28, 2003 | 02:27 PM
i looked at the new camaro performer mag at the store and it has all the codes for each year camaro (third gen i think) and it says code 22=low tps voltage so i set it right and it drives good for a day then the next day its a lttle low agin and the code 32 was was egr system failure so what does that mean i need to by a new egr or is there more to the system to change out
Old Jun 28, 2003 | 08:40 PM
Vader's Avatar
Old Jun 28, 2003 | 08:43 PM
Vader's Avatar
A '92 should have a non-adjustable TPS. The ECM will learn the closed throttle position on engine start as long as the voltage is below 1.0 VDC.
Old Jun 30, 2003 | 12:41 PM
sorry about that vader but i have a new car i dont have the 92 tbi anymore i have a 91 z28 convertible 305 auto does all that still apply i know you can set the tps but it keeps getting a little low and i cant tighten anything else up that i know 1 minute my car runs top notch then then at the next stop my car couldnt beat a 4 cylinder and is the eger the same sorry about that
Old Jul 2, 2003 | 03:05 PM
did you get that vader
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
