door panel
Old Sep 30, 2000 | 02:01 PM
ZDADDY92's Avatar
door panel
anyone know how in the hell to get the top piece of the door panel off, the plastic piece which sits next to the window?
92 Z-28
305 -5speed
160 thermo.
K&N Air Filters
B&M Ripper
14.7 @ 96mph
Old Sep 30, 2000 | 02:14 PM
Vader's Avatar
Daddy (nothing personal, I'm sure),
The upper rail seal and upper trim is attached to the inner door trim panel. Once the armrest, mirror, window, latch, and lock controls are removed, the inner door panel can be removed. It will hang from the top rail, and can be pivoted outward at the bottom, then lifted off the top rail of the door.
It is easy to remove the trim panel without damage if you have the trim clip removal tool. You'll probably want to replace the plastic clips, however, since they tend to get distorted when they are pulled from the door holes.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
