Hard Starting
Old Jun 26, 2003 | 02:55 AM
semcx's Avatar
Hard Starting
I'm posting this again, I'm trying to find someone that might know why this car will not start? When the Ign. key is truned on the volt gauge goes up and the check engine light comes on.
I have a 1988 Camaro with a 5.0L TBI engine and a 5-speed transmission. When I try to start the car it will take 4 to 5 times cranking it before it will start. When I first turn the key on I can not hear the fuel pump running and also the ignition key is very loose in the steering column. I checked the voltage at the fuel pump relay with just the key on and there is no voltage, you can watch the meter and on the 4th to 5th time trying to crank the engine you will see the meter go to 12 volts and the car will start. What is controlling the voltage to the fuel pump relay? The key switch? The Computer? Both, I’m lost at this point what could be wrong? Thanks
Old Jun 26, 2003 | 10:09 AM
Vader's Avatar
Check the replies in this thread .
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
