Non3rd gen, Durango question...
Old Sep 30, 2000 | 08:31 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
My friends check engine light came on. How do you break the codes on a Dodge? I understand the principle on a GM, grounding A and B and then reading the flashing check engine light. Can you do this on a Dodge and if so how? Thanks
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Sep 30, 2000 | 09:56 PM
Vader's Avatar
Rob,
If the EEC is similar to early '90s Nopars, you need to cycle the ignition switch without starting the engine. Turn the ignition key on, then off, then on, off, etc. Do this for five cycles within five seconds, leaving the ignition ON at the last cycle. Count the flashes of the "Service Engine" light for codes, just like on a real car.
I have some codes for some Nopars, if the system still works that way.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
my86bird
Oct 23, 2015 12:20 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
