IAC & TPS questions...
Old Oct 1, 2000 | 06:17 PM
Drowned's Avatar
Ok, first the TPS question:
I read the TPS adjusting tutorial and it says:
With VOM and jumper wires: disconnect the connector from the TPS. Using your jumper wires, make a connection allowing some room for the VOM terminals to contact the jumper leads and read the TPS voltage.
Ok, but my TPS has 3 connectors... which ones should I use?
I did a test on an extra TPS I have just guessing and I got 10 volts at WOT and 12 when idling (?!?!?!?) That's not even close to the 4.0 volts I'm supposed to be getting. Did I do it in the wrong connector? Any help appreciated
EDIT: Ummm... I'll ask the IAC question later.
• Check out my website! Just click here.
Click here to download your Third Generation F-body smilies.
[This message has been edited by Drowned (edited October 01, 2000).]
Old Oct 1, 2000 | 07:11 PM
freeze92's Avatar
Black wire = ground
Dark Blue wire = signal (test this one)
Gray wire = 5 volt reference from ECM
Middle wire (blue) should be about .54 volts at idle.
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
