Removing Emissions. Computer sideffects? BAD?
Old Oct 1, 2000 | 03:07 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Would i notice any side effects if i removed all my emissions stuff on my car? I have no emmissions here in iowa, so i figure, if i can i should right. I would gain power? Easier to work on my car? No huge computer problems? if someone could explain to me what would happen or what happened to them after they did this, and exactly! how to do this correctly i would appreciate it. Thanks
ENGINE SPECS:
305 TBI,Open Element,K&N 14x3,Hypertech Stage I,160 Deg. Thermostat,454 GM TBI
STEREO SPECS:
JVC Kalmeleon kdlx3,Infinity Kappa 2way 6x9's,PPI 4x6 Coaxials,PPI PC2400 AMP @ 2ohm
DEI Studio 12" 4ohm DVC,Custom Box:Exactly 1 Cubic Foot
Old Oct 1, 2000 | 08:27 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A high-flow exhaust system would do more for you than removing all your "emissions stuff". Get headers, high-flow cat, and cat-back system: It'll run better and still run clean.
You never know when emissions testing will come to your area, or you'll end up in a place that has it. If you remove your air pump, vapor canister and EGR (about all the "emissions stuff" you have with a functioning TBI), keep it in a box for the future. I hope you kept your factory air cleaner, too.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, ported heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Oct 1, 2000 | 11:12 AM
snflupigus's Avatar
too late i already ripped up my factory air cleaner. trying to get that valve out, and so i could get it to point straight forward. Im in IOWA. even if emissions came here, you could always get around it by getting checked in a small town by paying the guy 20 bucks. I know i could have done that at about 5 shops when i lived in fort collins, CO. Anyway, everything will work right, without that stuff. will there be a performance gain, because that would be nice but not why im doing it. I want to take it off to clean up the engine compartment, so engine work is easier.
Old Oct 1, 2000 | 11:17 AM
Vader's Avatar
Snuff,
What other "emissions stuff" are you contemplating removing?
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 1, 2000 | 10:02 PM
snflupigus's Avatar
you see, thats what im asking you. What do i remove. I would like to remove as much as i can to clean up the engine and make it easier to work on.
86IROC112
Aug 21, 2015 07:20 PM
theurge
Aug 21, 2015 12:46 PM
stalkier
Aug 21, 2015 01:54 AM
Bryan F
Aug 18, 2015 02:28 PM
3rdgenparts
Aug 8, 2015 07:09 PM
