350 Block new heads, cam, etc.........
Old Jun 28, 2003 | 05:42 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
if i go out and buy a 350 block out of a junked camaro what would i need to do to get abour 400 Hp out of it??????? could i pull this with maybe a different crank to stroke it (383), heads, a cam, then carburate it? ive got a 305 TPI now and i hear the TPI isnt worth much anything
Old Jun 28, 2003 | 07:59 PM
Vader's Avatar
TPI can be made to run, but there is a lot of labor and/or $$$ involved to get it flowing at higher RPMs. An LT1 intake and larger injectors would be ideal on a 383 for higher HP. Obviously, torque at lower RPM on the longer stroke engine shouldn't be a problem. A lot of LT1 people run the stock intake on a 383 LT1 and make well over 400 HP.
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
86White_T/A305
Aug 17, 2015 12:16 AM
