Ok I need this real fast...
Old Jun 28, 2003 | 08:04 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
The sun is setting and I am hoping to get this done this evening. Where is the high side service port for the AC? Please give a brief description on where it is. Thank you for your help and hopefully I can get this done before the sun sets.
Old Jun 28, 2003 | 08:32 PM
Vader's Avatar
About 10" below the low pressure test port, on a metal line that runs along the subframe rail back to the evaporator core case.
Old Jun 29, 2003 | 12:35 AM
trans87's Avatar
Thank you Vader. Did the retrofit tonight and now she blows cold air:hail: How much freon should I put into the system? I put in 24oz of refrigerant and 6oz of oil charge. How much do our systems hold of the 134a? I want to make sure it is fully charged and cold as possible Now is the time too to find out if I have any leaks. Let's see how long the charge lasts.
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
mattcanty
Oct 12, 2015 11:08 AM
racereese
Oct 3, 2015 03:46 PM
meeklay812
Oct 1, 2015 03:46 PM
